TwinTurbo.NET: Nissan 300ZX forum - 91 NA won't stop running.
Subject 91 NA won't stop running.
Posted by gschroeder on September 04, 2008 at 9:57 AM
  This message has been viewed 193 times.
Message The car has been resting for about 18 months. I bought a new battery, got it started and once it ran for awhile the idle was smooth and the drive was great. Then I parked, turned the key off and removed it, and it continued running. Not the typical misfire running but drivable running. Only way to stop it was to stall it with the clutch. But then the cluster warning lights stayed on and won't turn off which ultimatly drains the battery.
The ignition switch has been replaced and the ignition relay has been tested. There is no change. Anybody have any ideas?
